Old Reward plan
starcrush888
Hi, I've a question in regards to rewards. I'm currently on the old reward plan and if I switch to the $39 20GB plan. Will I be automatically switch to the new Public point reward plan? I prefer not to move to the new Public point plan.
Bobbymac_1726
You have to physically switch to the new point system and enrol. Feel free to change your plan all you want, i have never had any issues and I am still on the legacy program!
@starcrush888  it won't chnage you to the new rewards.  Plan change is just a plan change and you will still be on the old one
Meow
No. Your rewards are tied up with your account not plan. You can switch to whatever plan you want and current rewards will stay as is.
