06-18-2026 01:00 PM
Need help !! I have not been able to connect to PM . I have tried resetting it multiple times .. I received a message telling me that the SIM card I installed yesterday ended in 3683
however that is not the right SIM card number that I have ! Very frustrating
what can I do to resolve this ? It seems to be a porting issue and I hear that I will likely not be able to keep my old number. I was also asked if I wanted to try a different SIM card or try eSIM .. I responded yes to trying an eSIM card. Have not received a response yet
06-19-2026 05:30 PM
hi @phil26
yes, PM agent can do that, but you have to message them properly, not just post here
look like CS agent already talking to you. Please reply their message using this link:
06-19-2026 05:29 PM
can you send me a Esim ? email me something to fix this issue
06-19-2026 05:27 PM
can someone plz help me ! im still locked out
06-19-2026 09:00 AM
I was just told by Koodo that a transfer request for my number did not exist . Then the message said “ goodbye “ and hung up
unacceptable
06-19-2026 08:37 AM
Thank you for bringing this to our attention! The customer was already in a private conversation with one of our agents when the post was escalated. The agent will continue assisting them directly.
06-19-2026 08:14 AM
I received a message that I had a $5 credit to order an eSIM card to resolve this issue. However when I go to my account the only option is to buy a physical card ! I have 2 physical cards and neither one works ! I have tried purchasing an eSIM as well however the same message appears . INVALID PHONE NUMBER
06-18-2026 01:01 PM
are you porting in? ask PM to help with the login and sort out the port problem
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
