08-18-2025
12:54 PM
08-18-2025
02:25 PM
computergeek541
So I can call and use the internet after a number transfer but I can’t receive calls nor use texting at all
edited by computergeek541: changed category label as this discussion isn't related to Community
08-18-2025 01:02 PM
hi @Abej
Did you get a text from the old carrier, did you reply Yes within 90 mins?
and can you receive inbound phone calls, especially from Non-Telus/Koodo/PM phone? If you cannot the port was not done
It could be an incomplete port. PM porting support team can help. I have sent you the porting support team number. Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call.
And in case the poring team cannot help and ask you to submit ticket (or you rather submit ticket anyway), you can submit ticket by direct message:
