Number transfer
Phyllo
I was trying to transfer my number and mixed up the two numbers. How can I go back to correct it?
2 REPLIES 2
funpig1
@Phyllo
Did app allow you to do such a transfer? I would not think so. Could you not exit, reboot and try again? If not, contact the agent as as suggested below by Chalupa_Batman.
Chalupa_Batman
Hello @Phyllo
Please create a ticket with a CS Agent and they will fix this for you.
If you receive an error message that you are unable to open a ticket, send a private message to a CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 .
