3 hours ago
How long does it usually take to transfer a phone number from another provider to your new Public Mobile account?
52m ago
Hi Zuochen ,
please dont join the public mobile its a worst services provider in Canada there is no after service available after you get new number.
an hour ago
It will take a couple of hours but meanwhile keep your old SIM in your phone until it stops working then power off the phone and switch to the PM SIM.
2 hours ago
Correct!
So @Zuochen once you switch the SIM card to pm, text someone and ask them to call you back. If the call goes to voicemail, something went wrong and you would need to engage customer service via the chatbot for further assistance.
2 hours ago
usually fast, you can have the whole thing done within an hour
you got the port authorization text from the old service provider yet? if you received and replied, usually within an hour after
but if you put the PM sim in the phone and show no service or cannot make calls, that is not porting problem but account setup problem. So, can your PM sim card connect?
2 hours ago
@Sansan If calls works it's completed.
The critical thing is incoming calls, even if a port doesn't compete the outgoing calls can still work.
2 hours ago - last edited 2 hours ago
Once you reply to the text confirming the transfer it should be done within 30 but up to 4 hours of that.
You can switch the Sim cards and make calls and text to see if the public mobile is ready. If calls works it's completed.
2 hours ago
@Zuochen In my case less than an hour, but I had already set up my PM account with a new PM number to make sure everything was working before I ported. Once you have replied YES to the old provider's text message authorizing the port within 90 minutes it can take up to 5 hours after which it's best to contact customer service. That assumes cell phone to cell phone rather than porting in a landline number which can take a few days.
