3 weeks ago
I have gone through all of the number transfer prompts with the chat bot and my number still has not been transfered. Help me please.
3 weeks ago
new activation or existing subscriber try to port after ?
if new activation, did you use the PM app to port (Step 5 of subscription)
and is your PM sim currently active? can you make outgoing calls? Did you get a text from your old provider and did you reply YES?
if you cannot even make calls, it is not a porting issue but a problem with the setup, please open ticket with PM support.
