11-29-2023
08:17 AM
11-29-2023
07:28 PM
computergeek541
11-29-2023 09:14 AM
To port out, you start the process from your new provider
But first, make sure your PM account is currently active and you can receive text without problem. Login to My Account and get the account number from Profile page https://myaccount.publicmobile.ca/en/account/my-profile
While you are at My account, you might want to also disable Pre-Authorized payment just in case.
Go to Payment page, click Manage Subscription, then turn "Subscribed" to off
https://myaccount.publicmobile.ca/en/account/my-payment/manage-subscription
Now activate your new line with your new provider and request to port a number. Provide them PM's account number as the porting information
this is critical: Then still have your PM sim card in the phone, wait for PM to send you a text to confirm your porting request. You need to reply YES within 90 mins
After you replied yes, you can put your new sim card in the phone and wait until you get incoming calls. Once you are getting incoming calls, porting is completed. Your PM account will also be closed at this stage (you will no longer be able to login to PM My Account after)
11-29-2023 08:27 AM
On your current provider's website or by phone call to them, you start the process to port. Do not throw out or destroy your Sim card. They will message you asking if you are doing this with 90 minutes which you have to confirm. Once you do that, there will be instructions on how to proceed from there to the new provider. Can take a few minutes to hours to complete process.
If you have a physical Sim then with same phone, keeping the Sim card in phone try calling, texting. If doesn't work might have to restart phone a few times. Should be working after.
11-29-2023 08:22 AM - edited 11-29-2023 08:23 AM
@Emi2 You have to start the port request with the new provider leaving old providers sim card in the phone so you can reply YES to the confirmation text to port number
