Number transfer doesn't work
Fstan
I'm trying to transfer my existing number, it prompts me to login. I did, but site doesn't open...
@Fstan
If you are porting your number over from another carrier. You need to download the PM app and not the website to activate your new SIM and create a new account.
Chalupa_Batman
Hey @Fstan
If you're using a computer, this website is known to have cache issues. Go into your browser settings and enter Cache into the search. Clear it "for all of time". Then restart your browser and go into incognito mode and try again. You should be fine from there.
funpig1
@Fstan
Try rebooting your phone and try again.
Public818
Try login again later. Sometime, the system response will be slow.
