04-16-2022 11:23 AM
I am trying to change my number and when I select the number I want it states that the number change failed
04-16-2022 11:50 AM
If you found a number that you like and that is showing as available and no one answers on it then I would contact the support people. Some time ago I changed numbers. I have another account that changed fine. One didn't. I tried all the tricks that get mentioned here all the time but the support people ended up having to fix it.
04-16-2022 11:46 AM
@Corymw1 wrote:I am trying to change my number and when I select the number I want it states that the number change failed
@Corymw1 - you can change your phone number 4 times every 30 days, if you wish. Is there any chance you have done this more than 4 times within this period?
If so, you will need to wait another 30 days to change it again.
Otherwise, see other posts, or you can also try using a totally different device.
04-16-2022 11:34 AM
I would try using different browser. If that does not help, let us know...
04-16-2022 11:29 AM
Website can be finicky. Logout of your account. Try to clear cache, incognito mode or another web browser. Log back in and see whether that works.
