02-14-2023 07:56 PM - last edited on 02-14-2023 08:26 PM by computergeek541
Hello,
I just wanted be sure I can do this before I make a purchase. I have a number saved in NumberBarn, a wireline number. I want to purchase a plan from Public and port that number in. Will I be able to do so? And what will the process be for doing it? Thanks!
02-15-2023 12:04 AM
Here's what you need to know about porting from Number Barn....
https://productioncommunity.publicmobile.ca/t5/Get-Support/Port-number/td-p/819242#M549077
02-14-2023 08:05 PM
Check the number here first.
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do
Yes you can port out of NumberBarn. It will take longer though. iirc they use Iristel and it looks like a landline to this activation process. You just need all of the name address as registered at Numberbarn
02-14-2023 08:05 PM
@wychao Yes you can port in your number from Number Barn. You need to first purchase a PM SIM card from PM (could take a long time for delivery) or try Amazon or canadiancellsupplies.com for faster option.
Once you receive the SIM you can start the process using the activation link here: https://activate.publicmobile.ca/
