03-16-2019 11:26 AM - edited 01-05-2022 03:44 AM
Hi
Im not able to change/port number on self serve, im planning to port my active koodo prepaid number to my newly activated PM prepaid service
I belive i need to send moderator a message. Any format or what information do they need?
Thanks in advanced
03-16-2019 12:12 PM - edited 03-16-2019 12:12 PM
@jayc33m wrote:Hi
Thanks in advanced
Koodo prepaid and PM prepaid are sharing the same backend. Therefore, the Koodo prepaid number cannot be ported using the automated porting process. Send a private message to moderator for help as @Anonymous suggested.
03-16-2019 11:27 AM
@jayc33m wrote:Hi
Thanks in advanced
Send ONE (1) private message to them here and you'll get a form back to fill out identifying information.
Then hopefully they will get back to you as soon as they can between M-F 9-9 (ET) and Sat-Sun 9-7:30 (ET). But it could be up to a couple days.
Depending on your notification settings, you would get an email notifying you of a reply. Don't reply to the email. Get back here and see a red blob over the little envelope in the upper right of your screen and click on it to see the message.
