02-17-2021 06:49 PM - edited 01-05-2022 05:19 PM
My number porting failed, but the weird thing is I get calls on my old sim, but get texts via my new sim. (Good thing I have an old phone).
If I make an outgoing call via my public sim, and it says its my number, but I can't get calls to my public sim.
Need help, thanks.
02-19-2021 06:20 PM
See user335's tip below - this is what worked for me today.
02-17-2021 06:52 PM - edited 02-17-2021 06:52 PM
Hello @Orah4917 , - Welcome!
If you just ported your phone number from another cell provider it could take a few hours to complete the port. Using the other cell provider's SIM you should be still receiving calls on it, until the port completes.
If you ported from a landline it could take up to 7 days to complete.
Make sure you do not cancel your previous provider's services until the port is complete.
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
Occasionally, do one or more of the below:
*turn off your phone, leave off for a minutes, then reboot
*removing your SIM for a few minutes, then reinserting it
*go into airplane mode for a few minutes, then going back to regular mode
*reboot your phone again
