10-20-2021 01:44 AM - edited 01-06-2022 03:50 AM
Hi!
I've been trying to activate my card and porter my number from TELUS, but when I enter my cell phone number, it won't recognize my number as Canadian, so I can't continue with the process at all. I was given this number by TELUS in BC a few years back so it definitely should be Canadian. I can't find anybody who has had the same problem!
10-20-2021 05:04 AM
@selahmadland What exact error message did you get? Can you share the screenshot?
10-20-2021 03:02 AM
Lol....I set looking for that link in my drafts and there were so many I decided to discard as I looked and that was 45 minutes ago.
If the link supplied approves your phone number then it could just be erroring out and you need to clear your browser, reboot your device and use secret/incognito mode in chrome or Firefox.
Is there a chance it used to be a pc mobility or koodo prepaid number?
10-20-2021 02:33 AM
@BKNS27 : I'm not saying I'm right. Just that that's not what I said. If that makes sense. 🙂
10-20-2021 02:30 AM
@Anonymous
Made the correction…typing too fast without proof reading. Good catch.
10-20-2021 02:26 AM
@BKNS27 : I just noticed your other comment. I was suggesting that they not include the 1 ie. asking if they had.
10-20-2021 02:22 AM - edited 10-20-2021 02:27 AM
@Anonymous
I agree that the number a Telus number and it shouldn’t matter but I thought it is worth a try. Doesn’t hurt to check. 😉
The OP may have ported the number previously from a non-Telus carrier…who knows.
10-20-2021 02:19 AM
@BKNS27 : That doesn't make sense. It's all the Telus family. But what do I know.
10-20-2021 02:17 AM - edited 10-20-2021 02:29 AM
Some Telus/Koodo number can’t be ported over to PM.
Check to see if your number can be ported from their website:
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do?lang=en&appname=otherportal
Not adding 1 in front of your number as noted by @Anonymous
10-20-2021 01:48 AM - edited 10-20-2021 01:49 AM
@selahmadland : Is it a currently active number at Telus? Are you trying to put a 1 in front in that area code box (if it would let you)? Are the area code and prefix 3 digits?
10-20-2021 01:46 AM
Easiest way to activate is to use the live chat for activations.
https://chat.telus.com/chat/publicmobile/chat-pm.html?portal=publicmobile&language=en
