a week ago
Currently I am on the Grandfathered Old 90 Day Unlim Can-Wide-US-L-D, Unlim Global Text and 6 GB Data 4G LTE $150
Wished PM had the option to have 5G access as an Add-On Option, so like a Flat fee for 30 or 90 Day access and still retaining the Grandfathered Old 90 Day Unlim Can-Wide-US-L-D, Unlim Global Text and 6 GB Data 4G LTE $150
Also, If we had a E-Sim Phone, how would we be able to activate?
The 90 Day Return Plan cycle is Wonderful, Just not having the US-L-D included is disappointing
If they can now add more stuff eventually, Like, Access to Global Short Codes and Just topping up to use, Like how the Add-On Data works
If they can Add More Countries to the Global L-D List, and Add More to the Roaming List too, then that would Make PM the Best of Both Worlds
I was clamouring hard for these, in the past ppl said that it wasn't something PM would have done ever, or Not Priority, But now it seems Telus Is Finally Granting PM some Autonomy on these, and hopefully, More to see and more to come and experience
Too bad Siren App couldn't come Back Home, But, Can't complain when PM is Opening the Vault to something Grander, wonderful
Downloaded the App, simple, and definitely On Point, No Arguments
I wonder too, how can I access the VoLTE with my Motorola Moto One 5G Ace
a week ago
Oh ok, it was a long-shot anyway 🙂
a week ago
It doesn't save. It only allows my APN and one for "tethered internet".
a week ago
Does it let you create a new APN? I wasn't suggesting to edit. You need to keep the normal APN for data and MMS. My suggestion is only to create a new IMS APN in addition to what's already there.
a week ago
I thought I would give your idea of editing the APN on my moto g7+ a try and have discovered my APN is now greyed out with no option to edit the APN?!! It was never like this previously? What the?
a week ago
thanks for the tips @sheytoon My S21+ still unable to VoLTE 😞
a week ago
No need to fill in all the values, just do the ones I mentioned.
Name = ims
APN = ims
APN Type = ims
APN Protocol = IPv6
a week ago
a week ago
a week ago
@sheytoon , How would I set the APN in that Format?
a week ago
That means your phone is not attempting to register with the IMS network.
One thing you can try is to add a new APN with "name", "APN", "APN Type" all set to "ims". Choose IPv6 for the protocol and save it. That might force the device to attempt IMS registration.
a week ago
Here was something I was curious on
If one chose one of the 5G Plans, But Phone lacks 5G, Will one still have the 25 or 50 GB stuff?
a week ago
@sheytoon , when I checked it on that Menu *#*#Info#*#*, 3 Dots Top Right, IMS, IMS Service Status
IMS Registration: Not Registered
Voice over LTE: Unavailable
Voice over Wi-Fi: Unavailable
Video Calling: Unavailable
UT interface: Unavailable
a week ago
@sheytoon , how is IMS Registered?
a week ago
@sheytoon Where do I find that IMS in the Moto One 5G Ace?
a week ago
Mobile radio power should always be on. Turning it off is similar to airplane mode.
I'm not entirely certain about VoLTE provisioned, maybe somehow the phone knows if your account is allowed to use VoLTE or not. For me the better way to check is to press the 3 dots in the top right of that menu and select IMS Service Status. You need to be registered on the IMS network. This will allow your phone to use VoLTE.
a week ago
What they need to do is restore the non-expiring data add-ons full stop, no 30-day or 90-day ones, just go back to the way it was, I do like the unlimited data myself, just not at the expensive price range, they should at least make it somewhat affordable by allowing mid-tier plans to have it, if they wish to keep the 30-day add-ons, that at least meets everyone in the middle.
a week ago
I do agree, They need a 90 Day Add-On Option as well
I hope that they would add More stuff, like Global Short Codes and the ability to add $$$$ like How Koodo does with theirs, for Short Code Usage when using Global ones, Plus, I hope for expanded Roaming Countries added as well
Perhaps even 2 types of Add-Ons, One being fixed term Cycles, other Pay-As-U-Go
At least PM is getting better and Stronger, If Telus would be More Open to Making PM More than Just a Flanker Brand, Like Even Adding the Postpaid Option, But With the Online Support Only, and No Call Centers, Still a BYOD and DIYS( Do It Your-Self) Model
I'm happy to say the least, Hoping for More though
a week ago
I'm quite disappointed that any newly purchased data add ons expire 30 days after purchase. A poor decision by pm and one I hope they reconsider?
a week ago
I was looking at the Plans in My Self-Serve Portal, Prices Not bad, I would say, The Unlimited Data for the 5G, That I think PM should NOT have included, I'm quite Pleased at the Add-On System as it is
a week ago
a week ago
Just saw your screenshots....you should edit your first one since it lists your IMEI and phone #. Delete then use your photos edit feature to cross out those lines with "mark up" so you can post safely.
@sheytoon is the expert to explain the technical side of things better than I can....
a week ago
I'm Like Drooling with Glee, finally happy, so far, I haven't encountered Any Glitches yet, I am always Nitpicky
I just want All the Bells and Whistles that Normally on Postpaid, Just Prepaid Add-On-Like Manner
So far, I can at least say, PM is definitely getting Some LUV and that hopefully will fuel More Goodies down the Pipeline
a week ago
I'm a little gobsmacked by it all....but I do wish that their services and site would just work and not have the numerous glitches and oversights that exist.
a week ago
At least PM is finally listening to what People like me have been wishing for
a week ago
If I remember correctly....
#1= 3G calling
#2=VoLTE is active on your account and hopefully your phone? If it stays on 4G LTE during a call you are good to go...
#3=Video calls are not supported by pm but your phone can make them if you use a provider that does support them.
#4= not sure on that one?
a week ago
Not sure what these mean, when I dialed the *#*#Info#*#*
(4636)
What are these info in that menu?
Quite fascinated
a week ago - last edited a week ago
Plus this
a week ago
What do these mean?
Mobile Radio Power
VoLTE Provisioned
Video Calling Provisioned
EAB/Presence Provisioned
You can check if you have been provisioned for VoLTE by dialing *#*#INFO#*#* on you phone dial pad. While VoLTE is being rolled out in batches for existing customers it's entirely dependent on your device being an approved VoLTE device by telus/pm with the whitelist being a guide but it's YMMV for VoLTE capable devices not on that list.
Your legacy 90 day plan doesn't offer the greatest value anymore with the ability to schedule a change plan on next renewal to the $39/20gb 4G LTE plan. How much do you call the US every 30 days? You surely have the holiday gift international minutes add ons from the "more is merrier" campaigns since 2019? If not the $15/1000 US minutes add on is good value at $0.015/min. The $11/30 days in savings ($33/90 days) should more than cover the cost of the US minutes add on?
Edit:
E-sim is done thru the app.
