Not working
01-06-2022 04:28 PM
01-06-2022 10:11 PM
@125 wrote:My phone is busy and I have a credit card on file
@125 - ok, so when people call you they get a busy signal?
Do your outgoing calls, texts in/out or data work?
Can you try your SIM in another phone to see if incoming calls work?
Other troubleshooting to try:
*turn off your phone, leave off for a few minutes, then reboot
*removing your SIM, then reinserting it
*go into airplane mode, then going back to regular mode
*reset network settings on your device
01-06-2022 04:38 PM
Not sure what you mean by "line is busy". Do you get busy sound whenever you dial ? Can people call you ? Can you text out ?
01-06-2022 04:36 PM
You need to be a bit more clear on what you are experiencing and what the problem is.
Log in to your account to make sure your plan is Active
01-06-2022 04:35 PM
Line is busy and I have a active credit card on file so I’m not able to use the phone
01-06-2022 04:33 PM
01-06-2022 04:31 PM
Well, what is this supposed to mean?
Do you have service? Can you send/receive SMS/calls? What your PM account says?
Little bit more details is needed.
