11-19-2018 10:20 PM - edited 01-05-2022 02:32 AM
A few days ago I realized that most of the time, people calling me were automatically being sent directly to voice mail. Today I realized that I am not receiving any cellular texts. I have an iPhone 6s and am still receiving iMessages but not SMS/MMS texts. I can make calls without problems. FWIW, I upgraded to iOS 12.1 just before this became a problem.
What should I do to fix this?
Phones
11-20-2018 12:22 AM
11-20-2018 12:10 AM - edited 11-20-2018 12:11 AM
@poppingThank you! That fixed the problem in 5 minutes.
11-19-2018 11:34 PM
@PDub wrote:@poppingHi. What is the stolen/lost phone trick?
1. Login to your self-serve account.
2. Report your phone lost/stolen using [Plan and Add-Ons] --> [Lost/Stolen Phone]
3. Logoff
4. Wait 5 minutes and login again
5. Report your phone found.
6. Re-start you phone to provision your account again. i.e. enable all features of you plan again.
If this trick failed to get thing working again, you should send a private message to moderator for help. But the wait is about 48 - 72 hours. Good luck.
11-19-2018 11:21 PM
11-19-2018 10:44 PM
@PDub wrote:Hi. No, haven't done a number port. I can't tell from your post if that's a possible cause of or a possible solution to my problem. Will have a look at link you posted. Thanks for replying.
If you have not ported a number from other provider, your account may not be provisioned correctly. You may try the stolen/lost phone trick to run the provisioning software again.
11-19-2018 10:41 PM
11-19-2018 10:38 PM
@will13am, the link you posted is permanently deleted for some reason.
11-19-2018 10:33 PM
11-19-2018 10:25 PM - edited 11-19-2018 10:41 PM
@PDub, did you do a number port? The symptom you have reported is synonymous with a stuck port. If the port has been submitted more than about 4 hours ago and the symptom persists, then you will need to seek moderator team assistance to resubmit the port. The moderator team can be reached via private message using this link. Please include in the private message account number and PIN code along with a detailed description of the issue and the required resolution. This will speed up problem resolution significantly. Refer to the following knowledge base link for additional information on contacting the moderator team.
