Not receiving texts from a specific local number
12-18-2019 04:30 PM - edited 01-05-2022 08:36 AM
I've been having issues receiving texts from this one number, and it seems to be specifically this number. On rare occasions, they'll send me a text and I'll just never receive it, even though it says "delivered" on their end. Their phone is an android while mine is an iPhone, if that helps. Is there a way to receive these "lost" texts?
Phones
12-18-2019 05:32 PM
@ChuckYeah wrote:
@ChuckYeah I'm also an Android user....iMessage overcomes the limittations that sms has with character limits etc, and it also allows families to communicate with their kids that only have iPads. It's also better when travelling etc.
12-18-2019 05:24 PM
@geopublic If you have unlimited texting, what is the benefit of Imessage? Signed an android guy!
12-18-2019 05:13 PM - edited 12-18-2019 05:16 PM
@amy4947 wrote:No, they've had an Android for a while; long before we started texting.
Sending a message through iMessage isn’t as simple as it looks. If an iPhone user sends a text the Messages app first of all checks if the recipient is registered Apple’s iMessage service and if he or she is, iMessage sends an iMessage in place of a normal text message.What this effectively means is that for iPhone users the choice between iMessages and SMSs is made by the app, not the user. The only way the user can differentiate is through the color of the message, green for SMS and blue for iMessages. This ensures a seamless transition between each service without creating a hassle for the user.
Where the Messaging to Android Users Problem Starts
This is where things get messy. If you are a user you switched from the iPhone, your number will still be registered in Apple’s directory. So, when someone using an iPhone sends you a message, that message will go to Apple’s servers but not make it out. Why? Because you don’t use an iPhone anymore. However, the sender of the message will have no idea because they will get a delivered notification since their message has been received by Apple’s servers.
@amy4947 This problem can also occur if you never possessed an iPhone. If you purchase or are given a number by someone who was using an iPhone you fall into the same trap and messages sent by iPhone users will not reach you.
Android not Receiving Texts from iPhone? How to Solve this Problem?
The most obvious way to get rid of this issue is to unregister your number from Apple’s iMessage service directory. Apple has created a tool to help users do so easily after they faced the possibility of lawsuits.
Go to Apple’s Deregister and Turn Off iMessage website. Enter your phone number and Apple will send you a text message with a confirmation code which will be required when prompted by the site to prove you have possession of the phone number in question. After a few hours, you will be unregistered and receive texts from iPhone users as standard SMSs.
Another method can be used if you still have your old iPhone, without going through the online tool. Insert your SIM into the iPhone and open Settings. Then go to Messages and disable iMessage by greying out the slider and do the same to disable the FaceTime slider as well. Now simply return you SIM to your current phone and everything should work perfectly.
12-18-2019 05:06 PM
@amy4947 Try these:
a) turn iMessage OFF for 5 minutes, then back ON
b) confirm your message settings: Settings >> Messages >> iMessages ON, Send as SMS ON, MMS ON >> Send & receive: should show your PM phone number and your Apple ID email
c) confirm you have cellular data and roaming ON.
12-18-2019 05:04 PM
12-18-2019 05:02 PM
12-18-2019 04:59 PM
@amy4947 wrote:I don't know what network they're with, but I've sent texts to all different networks without any issue; it's only ever been an issue with this number.
I'm curious if they have issues with other numbers
12-18-2019 04:58 PM
12-18-2019 04:57 PM
Most of the time, yes. But just this morning, I texted them something, they replied, but I never received it.
12-18-2019 04:54 PM
Cyberspace black hole! 😉
Seriously, though, my wife has experienced that very thing, except that it seems to only have been her texts that never get to the target. She used to be with Rogers, and has sent texts to one of our grandsons, and on more than one occasion, he never received them. In this case, they're both Android phones, and I THINK the grandson in question is on the Telus network(either Telus or Koodo). We were once at a soccer game with him, and she sent a couple of texts to him, just to experiment, and he did get one, but not the other. That, and occasionally, a text can take a couple of hours to show up on the intended target's phone.
Is the person sending you those texts on the Rogers network, i.e. Rogers, Fido, or Chatr?
12-18-2019 04:50 PM - edited 12-18-2019 04:52 PM
@amy4947 wrote:The number isn't blocked, but also doesn't appear in my usage history. They just send me a text and it just never reaches me. The text I sent them is there, but not what they sent me.
What happens when you send them an sms and they reply to it does it come through? If yes, it means that the number they have in their contacts is incorrect and thus the text that they are sending to you is going somewhere else.
12-18-2019 04:47 PM
I suggest you contact moderators about it
12-18-2019 04:46 PM
It's just a regular SMS.
12-18-2019 04:45 PM
12-18-2019 04:45 PM
@amy4947 wrote:I've been having issues receiving texts from this one number, and it seems to be specifically this number. On rare occasions, they'll send me a text and I'll just never receive it, even though it says "delivered" on their end. Their phone is an android while mine is an iPhone, if that helps. Is there a way to receive these "lost" texts?
@amy4947 Is it a regular text (sms) or a picture text (mms)?
12-18-2019 04:42 PM
Can you login too your selfserve and see if it is logged there?
Also check that you didn't accidentally block that number
