Not receiving password reset link.
willmountain90
Hey there, I've requested multiple password resets to cancel my plan and can't get an email to reset my password and my saved password doesn't work.
Thanks
Since you're back...what recording do you get when you dial 611? If you know your 4 digit account pin then you can use it to turn off autopay. You can also hear your renewal date and then pause your credit card the evening before until mid-day of that day. That will not let it renew and go into suspension. Then after 90 days the account will die.
willmountain90
Nope!
Logan2021
Sometimes it may be in the  junk folder. Have you checked there? I've had some password reset links sent there.
dabr
@willmountain90    Submit a ticket via chatbot for customer support here:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Or send a private message to CS_Agent here:  https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Their response will appear in the message box top right of your screen.
Porting out your number will automatically close your account but if you want to remove any payment card, then you need customer service for that.
