03-04-2022 11:14 AM - last edited on 03-04-2022 07:17 PM by computergeek541
I have just join Public mobile but after six days still I am not able to receive any calls why
03-07-2022 06:15 PM
@cdc1LOGIC wrote:Could I get this number as well. Very frustrating....
Yup, sent to your Community inbox. Please check the envelope icon on top right.
03-07-2022 06:13 PM
@cdc1LOGIC - do you mean the porting phone number?
Check your inbox, I have messaged you.
03-07-2022 03:31 PM
Same problem here. I did confirm but it might have been outside of time limit. What to do now?
03-07-2022 03:30 PM
03-04-2022 10:36 PM
@Mr7i5Q wrote:I have just join Public mobile but after six days still I am not able to receive any calls why
@Mr7i5Q -
If you activated with a new number, all your services should be working by now. Does outgoing calls, and text in/out, and data work okay?
Ensure your Do not Disturb setting has not been accidently turned on.
Some troubleshooting to do/try:
*turn off your phone, leave off for a few minutes, then reboot
*removing your SIM, then reinserting it
*go into airplane mode, then going back to regular mode
*reset network settings on your device
*try your SIM Card into another phone to see if calls are received on it
If still issues with the new phone number/account, contact the Public Mobile Customer Support Agent (CSA)_Team to check your account, there are two methods to reach them found here:
If you porting over a number from another provider, and missed the 90 minute window, submit a ticket via this link to re-initiate the port:
Link to contact Customer Support Agents (CSA) for porting to Public Mobile
If you just ported your phone number from another cell provider it could take a few hours to complete the port.
Using the other cell provider's SIM you should be still receiving calls on it, until the port completes.
Landline/voip numbers take 3+ days to complete.
Make sure you do not cancel your previous provider's services.
Incoming calls are usually the last to port over.
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
03-04-2022 11:29 AM
Could we get more information so we can help determine what the problem is?
- Did you port your old number over from another carrier or did you pick a number number?
- If you ported over to PM, did you reply to the text to confirm you are porting your old number to PM?
03-04-2022 11:20 AM
Did you port your number?
Did you create self-serving PM account? What does it say there? Is your account active?
03-04-2022 11:17 AM
@Mr7i5Q did you port your number from another provider? If so, did you receive a text from your old provider to ask for your permission to port the number away ? did you reply YES within 90 mins? That is a critical steps for porting. And if it was missed, the porting would got stuck
If that is the case, the number would still be with the old provider. There is a number to call to talk to porting support team in person. i will private message you the phone number. Please check your Community inbox, envelope icon on the top right
