05-25-2021 02:32 AM - edited 01-06-2022 02:45 AM
I input my old SIM card into a new phone back in January. Since then I have not been able to receive calls from my kids school or any government health agencies/hospitals. When they call they get a message that my phone number is out of service. Any idea why or what I can do to fix this? All other calls and services are working fine.
05-25-2021 11:46 AM
@kzavadukJust to be sure any call forwarding settings are not inadvertently causing this, dial the following two codes:
##21#
##004#
Then you may want to test calling your number from a few sources, especially from non-mobile/land lines. As part of this you can try downloading one or both of the TextNow or Fongo mobile Apps, and see what happens when you call your number from that. If you also like you can PM me your number and I can test calling you from various line types.
05-25-2021 06:06 AM
@kzavaduk wrote:I input my old SIM card into a new phone back in January. Since then I have not been able to receive calls from my kids school or any government health agencies/hospitals. When they call they get a message that my phone number is out of service. Any idea why or what I can do to fix this? All other calls and services are working fine.
If you do not have the previous phone, are you able to test your SIM into another compatible phone and test? To rule out a phone issue.
With the phone you are having issues with:
05-25-2021 03:22 AM
What phone are you using?
Any chance those specific numbers have been accidentally blocked? If it's an iPhone go to
Go to Settings > Phone > Blocked Contacts.
I read somewhere if you're sharing the same account and the other person has blocked the call your contact list number will also be blocked.
05-25-2021 03:05 AM - edited 05-25-2021 03:08 AM
@kzavaduk wrote:I unfortunately don’t have my old phone anymore. Do you think getting a new SIM card would be worth a try? 🙂
That's unlikely to help. As I was saying before, the settings that could possibly make calls go be redirected to a different phone number that is not in service are the call forwarding settings. Those are set at the account level, but changed by setting them using the device.
As for if the SIM card is faulty, your services wouldn't work at all if it were faulty.
05-25-2021 02:57 AM
05-25-2021 02:50 AM - edited 05-25-2021 02:55 AM
@TheGx wrote:@kzavaduk :Try put your SIM card back into your old phone or any other phone see if you can receive those government calls, if you can it means problem with your new phone - since everything works fine in another phone.
The only device settings that I can think of that could possibly cause your phone number to be reported out of service would be the call forwarding setttings, and even then the calls would have to be phone number that doesn't exist. Are the phone numbers saved in your contact list? Some devices automatically reject calls that aren't.
05-25-2021 02:37 AM
