Not receiving authentication sms
Topmega
Hello
I just moved my line from freedom mobile to public mobile and I have not been receiving authentication sms code send to my message from 28849 when I login into my investment account. I have also checked my settings if this number was blocked from message delivery but not. Please does anyone have idea or know what I should do.
Thanks
19 REPLIES 19
@Topmega
Your welcome. BTW.... to tag a member just tap the "@" key for a pop up box to appear with members usernames in it. If you don't see the members name you want just keep typing til you do....
Topmega
Thank you for your help
Topmega
Thanks for your help
@Topmega
Some investment portfolio companies take up to 7 days to recieve 2FA test messages. Try again after 7 days to see if you can recieve those texts then.
Note:
Switching to the 3G network only will not fix a texting issue as texting works on both the 3G and 4G LTE network. This troubleshooting tip will only work for certain calling issues as pm uses the 3G network for voice calls.
@Topmega wrote:
Thanks.
I just tried the Canada Govt website, it works but others like my investment acc is still not working. This is frustrating.
@Topmega  it takes time.. different systems require different length of time.  This is part of porting and not because you are in PM.  Couple more days and you will be good.
Topmega
Thanks.
@Topmega wrote:
Thank you so mush.
I do receive sms from friends just the 2FA SMS am not receiving.
Hope they get it fixed, this is really frustrating I really need to access my account.
This is normal.  The bank do this for security measure to avoid SIM Fraud.
Same thing happens with short codes.  This system generated app needs time to learn the new "home" of your phone number
It should be all good in couple days
@Anonymous wrote:
OH MY!!! S--S do you UNDERSTAND what OP is asking????
He is NOT receiving AUTHENTICATION code from his bank/investment company. Nothing wrong with his service.
Per experience, auth. codes in recently ported MOBILE numbers will take a while to start arriving.
@Topmega- go to Canada Government site and try to log in; they will send you auth. code by SMS. Let us know it That works.
t_p
@Topmega
A few more things to try:
- Clear cache of messaging app. Stop and restart.
- Reset network settings.
Topmega
Thanks, I tried still not working.
Topmega
Thank you so mush.
t_p
@Topmega wrote:
Hello
Thanks
@Topmega
Try putting your phone on 3G (WCDMA) to see if it helps.
@Topmega wrote:
Thanks for your help.
I already port to public mobile like 4days back and their service are great except am not receiving authentication sms when I login in my investment account. It shows the code have been sent to my message but I don't receive it.
@Topmega
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
and you can try to reset network settings and Changing APN Settings,
Spoiler
for IPhone
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit  Here link,
click Here link,
How to reset network settings on an Android device
  1. Open the Settings app on your Android.
  2. Scroll to and tap either "General management" or "System," depending on what device you have.
  3. Tap either "Reset" or "Reset options."
  4. Tap the words "Reset network settings."
   or visit  Here link,
and go Changing APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
and do Rebooting your phone,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
and can you try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
for android visit Here link ,
This is quick and simple,
or if you can't fix it you have to Contact Customer Support Agent by CS_Agentand Explain your issue to they can solve your issue, they are nice service Team the will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent, and Submit a Ticket
Spoiler
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to Customer Support Agent by CS_Agent,Click Here link,to get started.
  • or you can send a private message to Customer Support Agent by CS_Agent, by Click Here link,
  • You’ll need to be logged in to your Community account for the link to work.
  • your account number,
  • your phone number,
  • your account 4 digit pin,
  • your Email address,
  • Customer Support Agent by CS_Agent, will Response to your inbox by private message
  • During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
    • Monday to Sunday: 6 AM to 10 PM EST
         Good Luck...
this is a different issue.
You are getting regular SMS from friends now?
 It is normal that sms  from financial intuitions (or other shortcodes) won't work right a way, it sometimes take couple days to a week.  this is to avoid SIM fraud.
Since you ported into PM for 4 days already, you should start getting those 2FA SMS soon, maybe Monday or Tuesday.
Topmega
 @Topmega : The replies from S--S and hTideGnow  are for porting.....not 2FA texts.
@Topmega
if you miss it the SMS try to do Rebooting your phone with SIM card freedom mobile,
Make sure that you have the old SIM card in your phone when you're porting your number. You should get a SMS message from your old carrier asking to confirm if you would like to port your number. Your reply should be: YES.
The confirmation message can take a few minutes to come in. You have 90 minutes from the time of request.
if you stuck with Transferring your old Phone Number,
Here’s how to contact Customer Support Agent by CS_Agent,
  • which carrier,
HALIMACS
@Topmega
It has been previously reported that authentication codes such as these may take a few days to begin for a new service with Public Mobile.
See this prior thread for helpful details & discussion:
Solved: Re: Not receiving SMS verification text from Wealt... - Community (publicmobile.ca)
@Topmega  so, you have not got the message to authenticate the move yet?  You have to reply within 90 mins.  I will  message you the number to call to confirm the porting status.  Please check your Community inbox
