11-02-2022 06:42 PM
Hello
I recently signed up for a Public Mobile plan -- moved from Rogers.
I am not able to receive text messages.
Please help,
M
11-02-2022 06:45 PM
Thank you:) Please send info. I have messaged one of the customer service agents and have not had any response yet.
11-02-2022 06:44 PM - edited 11-02-2022 06:45 PM
@daypas are you receiving incoming calls? I am afraid you are not
A critical part to porting is to receive a text from your old provider and reply YES within 90 mins. If you are not receiving calls and text on your PM sim card and can only make outgoing calls, then you might have missed the step and hence porting was not completed
There is a number to all to talk to live support and the can re-trigger the process for you. I will message the number to you via the Community inbox. Check the envelope icon on top right. Call them and get it fixed
But if you are receiving calls, receiving text from friends, just not receiving system text like 2FA from banks, then it is normal. Those text can take as many as 7 days to come. Systems need longer to learn you changed provider and some banks purposely put that delay to avoid sim fraud. So, you might need to wait a full week for those system texts to come
