04-16-2026
12:10 PM
04-16-2026
05:13 PM
computergeek541
04-16-2026 12:29 PM
If it has been more than 10 business days (2 weeks), then contact customer service agent. Usually sent via Canada post with no tracking information.
If you need SIM card right away, it might be easier to purchase instore from vendor (Telus, Koodo or Mobile Klinik stores). Keep the receipt and submit to CSA for reimbursement. Amazon also sells with prime shipping.
04-16-2026 12:13 PM
hi @Pegahmanaf
Sim card delivery can be 3 days to 3 weeks here
But best to ask PM support agent for status update, you can submit by direct message:
Better to ask if you can pickup another one from a nearby Telus or Koodo store instead of wait longer to have them resend a new one
04-16-2026 12:13 PM
Ask PM , maybe they need to resend you a new one
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
