02-08-2025
02:43 PM
02-08-2025
03:21 PM
computergeek541
I am trying to set up my account and I’m not getting any texts so I can’t even enter the verification number because I’m not getting the text.
02-08-2025 04:50 PM
Call your old carrier and check if they sent a text to your phone confirming you are porting over to PM (with the old SIM in the phone).
If they said yes then porting is in process.
But if they said no then you need to look for the old SIM. If your old carrier is Telus or Koodo then you are in luck and PM could help you but if it isn’t the 2 carrier. You need to purchase new SIM and have them activate for your old account then follow the activation steps.
02-08-2025 04:39 PM
What if old sim is in garbage 🫣
02-08-2025 04:37 PM
Just have a CS_Agent look into it for you so pm them. If you old SIM still works then porting wasn’t completed.
02-08-2025 04:20 PM
I think I didn’t overlap when starting the new sim. I don’t know how to fix that though. Start over completely or go to my previous carrier to change things? Not that they will appreciate that.
02-08-2025 03:50 PM
Port means you want to save your phone number from the old provider, and use it for the new one. This way you don't lose your contacts and your phone number doesn't change. So you "port" and send the number from your old carrier to your new carrier. It only works if your old phone plan is still active, otherwise it get s bit more tricky. Reach out to PM by sending a message to cs_agent
https://productioncommunity.publicmobile.ca/t5/Get-Support/How-and-where-do-I-send-a-message-to-CS-A...
02-08-2025 03:48 PM
This^^^ pick a new number temporarily while you figure out the port situation. Send a message to cs_agent on the community messages tab to figure things out
02-08-2025 03:47 PM
Nope, you need to download the PM app and activate the SIM. You can skip bullet #2.
Here is a more detailed information on how to activate the SIM & create an account.
The steps must be followed in exact order if you are porting your number over to PM:
How far did you get when activating the SIM?
02-08-2025 03:43 PM
I thought it switched over/ported as soon as I got the SIM from PM
02-08-2025 03:33 PM - edited 02-08-2025 03:36 PM
Porting is transferring your number from your carrier to another carrier.
If you currently have a telephone number with another carrier and wait to move it to PM. You can port it over to PM or if you don’t want to port over or you don’t have a number…just pick a new number that is offered when activating the SIM.
02-08-2025 03:29 PM
What does port mean? I have a public mobile sim card
02-08-2025 03:27 PM
hi @Momof6girls are you porting your number into PM? and are you getting incoming calls?
if port is not done, the verification code would be sending to your old carrier's sim card. Check there
02-08-2025 03:26 PM
I restarted my phone and I’m not getting calls or messages. My phone number isn’t even verified yet but I can’t get the OTC bc I’m not getting texts!
02-08-2025 03:23 PM
@Momof6girls wrote:I am trying to set up my account and I’m not getting any texts so I can’t even enter the verification number because I’m not getting the text.
Some of the time, a device restart is need before service starts working, but I'm going to assume that was already tried. Are outgoing calls and outgoing text messages working?
