11-09-2023 05:48 PM
11-27-2023 03:20 PM
Members have indicated with the Samsung S20 FE 5G will not show 5G on their device but when a speed test was done…it meets the 5G speed.
You can search on this topic for this device in 5G.
11-27-2023 02:08 PM
I've switched to a Samsung Galaxy S20 FE 5G, and I still don't have 5G. I switched also to a physical SIM due to this phone not having eSim capabilities.
I don't see 5g as an option yet if I put a Rogers SIM in the device, I get 5g instantly.
Do I need a different SIM?
11-09-2023 07:53 PM
11-09-2023 06:37 PM
Your iPhone 11 Pro is eSIM compatible but is not 5G compatible. It is an LTE phone so that will explain why.
11-09-2023 06:20 PM - edited 11-09-2023 06:21 PM
@Chalupa_Batman wrote:Exactly what @Phil_Adelphus
However, you should do a speed test and see what speeds you get. Sometimes folks, like myself, get a 5G plan even know I have a 4G phone for the data allotment over speed. JMO.
A 5G device isn't necessarily required for the full 250Mbps speeds that Public Mobile advertises. While the 5G network does help with network capacity, the LTE network is capable of speeds much faster than 250Mbps.
11-09-2023 06:13 PM
11-09-2023 05:52 PM
@Azkikr Because the iPhone 11 is not 5G capable, that started with the iPhone 12.
