12-29-2014 05:52 PM - edited 01-04-2022 12:29 PM
11-09-2015 10:03 AM
Excellent, then you should still be able to get phone support. Does 611 work on your cell phone?
11-09-2015 10:03 AM
11-09-2015 10:03 AM
11-09-2015 10:02 AM
Thank you for your advise. I have this account for a couple of years.
11-09-2015 10:01 AM
Note: If you have been with Public Mobile prior to January 2015, then you can call them directly, either using 611 on your phone (if you can make outgoing calls) or their toll-free number (which I don't know off hand).
11-09-2015 10:00 AM
11-09-2015 09:58 AM - edited 11-09-2015 10:02 AM
@Kony wrote:My phone number is XXXXXXXXX. I am not able to make or receive a phone call since yesterday morning. I had people trying to call me, but a message comes on every time about a wireless voice maibox... Please help me, I am an elderly person and I rely on my phone for emergency calls. You can email XXXXXXXX or call XXXXXXXX. Thank you.
@Kony, please do not post personal info on the forum as it is completely public and searchable.
You will need to send a message to Public Mobile through this link.
Have you been able to receive calls in the past or is this a new account?
11-09-2015 09:57 AM
Hi. You better remove your Cell #, as this is a Public forum, and Google has a Fat Nosey Spy Bot that has tendency of collecting data for its Leather Book archives. Unless you really want Unwanted Calls, Best remove it now
11-09-2015 09:53 AM
My phone number is 647-768-2197. I am not able to make or receive a phone call since yesterday morning. I had people trying to call me, but a message comes on every time about a wireless voice maibox... Please help me, I am an elderly person and I rely on my phone for emergency calls. You can email gabyd@rogers.com or call 416-417-5961. Thank you.
08-25-2015 03:32 PM
@libranrjy3, You should consider removing your Cell #, Sim Order #
Any Personal info, Cell #, Sim #, Sim Order #, CC #, Email, stuff like that should NEVER be posted on the community at all
This ONLY should be applied when Emailing Public Mobile Support ONLY
Google's NOSEY Spy Fat Bot has the tendency for digging info for its special black book archives, which is NOT a GOOD thing at times.
Unless you want the unexpected Call or Text, Best remove this NOW
08-25-2015 03:25 PM
@libranrjy3 please delete your phone number. It is of no use to the Communitty in assisting you, AND effectively publishes it to the world. Posts here are totally public, not private in any way.
08-25-2015 02:57 PM
I phone has stopped wrking. Can not make or receive any call.
08-11-2015 10:33 PM
08-09-2015 10:20 AM
1) Try power cycling your handset (on-off)
2) If this still does not work, try removing and re-inserting your SIM card
Let me know if this helps?
08-09-2015 07:21 AM
Hello,
My phone was working fine last night, but as of this morning it thinks that every call I make is long distance and I know I am able to call anywhere in Canada, but now the phone won't let me make calls, but I can receive calls.
How do I fix this?
05-06-2015 10:34 AM
Did you try to reboot your cell phone?
If your issue have not been fixed after the reboot, you may have to send an email to Public Mobile.
How to send an email ?
Click on this link : https://publicmobile.ca/en/on/contact-us
Then, at the bottom right of the page, click on "Email away" button.
- Choose "Technical Issues"
- Choose "Calling and Text Messaging"
- Choose "Voice calls not working"
- Choose "The problem affects all my calls"
- Choose "My phone is receiving a signal"
- Choose "I believe my account is paid and up to date"
- Choose "I have not tried a SIM card in another phone"
Then click on "Email Us" and fill up the form.
An agent from Public Mobile will try to answer you ASAP.
05-06-2015 10:29 AM
I have the same problem with my iPhone 5.
Could you please verify and resolve?
02-05-2015 04:17 PM
