Not able to access My Account
chaluke2
Hello, I purchased a SIM card and a plan last month. After some effort in transferring my number, my SIM was activated and I have been using my new plan without any problems this past month. However, when I log into my PM account online to check my usage and plan details, the first prompt I get is to finish activating my SIM. It won’t let me see any account details. I’m sort of stuck because I can’t activate my SIM to get past that step (it’s already activated) and I can’t see my account details without that step. Please help!
2 REPLIES 2
HI @chaluke2
 Please try again using Incognito/private/secret mode on your browser to login My Account, or try using the PM app (logoff the app first and log back in)
if same, then  submit  ticket by direct message:
slusagm
ask PM to help, open a ticket with them. Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
