07-26-2022
02:06 PM
07-26-2022
04:45 PM
computergeek541
Hello,
I've switched over from Rogers a few weeks ago and just realized I am not receiving calls or texts. Whenever someone calls, the caller gets "The person you are calling is unavailable..." message and does not even go to voicemail. Any assistance regarding getting this resolved?
Thank you
Sylvia
07-26-2022 02:51 PM
Thanks! I have called rogers and got them to manually authorize the porting.
07-26-2022 02:17 PM
@sylv_przy Look like it is a stuck port, the porting wasn't completed
Were you Rogers account active when you ported?
did you get a text from Rogers to ask for your approval and did you reply YES? This is a critical step and you were supposed to reply in 90 mins
No worry, as long as your Rogers account is still active, you can still port the number. But you will need to talk to a live support team and ask them to re-trigger the porting request. I will send you the phone number. Please check your Community inbox, envelope icon on top right
07-26-2022 02:16 PM
Wow! Few weeks without communication?
Did you port your Rogers number to PM?
When you call somebody what number do they see? Your 'Rogers' number or something else?
