02-03-2021 09:06 PM - edited 01-05-2022 05:08 PM
Hello,
I searched this forum but could not find exact info about compatibility of Nokia 7.1 plus.
Can anyone here please confirm if this device is compatible with Public Mobile Sim.
02-05-2021 01:32 PM
Thank you so much
Yes that is my mobile.
02-04-2021 01:55 AM
@chiragmalla :Did any of the replies posted to this thread you created help you find out if your phone works with Public Mobile?
You can also use the online phone compatibility tool by clicking on her started at bottom of this page.
You should choose one of the above posted replies as an accepted solution by clicking on the accepted solution button above post that helped you most, this will mark your created thread as solved, and will help others with similar questions too.
02-04-2021 12:21 AM
@chiragmalla wrote:Hello,
When you buy, see that it's the same TA model number. Lots of seller cut and paste without knowing the difference. If it's the same price, I suggest North American variant to get best frequency compatibility.
02-03-2021 09:16 PM
Public Mobile uses the following frequency bands:
3G = 850 (5), 1900 (2)
4G = 850 (5), 1900 (2), 700 (12/13/17/29), 1700/2100 (4), 2600 (7), 1700/2100 (66)
Is your phone the following:
https://www.anawazonline.com/nokia-7-1-plus-ta-1046-dual-sim-64gb-4gb-ram-4g-lte-3052.html
If it is, then it is compatible with Public mobile.
02-03-2021 09:14 PM
@chiragmalla As long as the phone supports the frequency listed below, it will work.
