No texts
Pcm
I’m not receiving any text messages. It’s stopped a few days ago. I removed the card and still nothing. I’m requesting a ticket
10 REPLIES 10
@Pcm  Are you on the $10 50/50 plan? Have you used up all your outgoing texts? Check on your overview page to see if your texting feature is still there. Even if you've used them all up you should be able to send MMS.
@popping wrote:
Are you using iMessage on iPhone?
If yes, you need to enable SMS on the iMessage settings to send and receive SMS to and from users using Android phone.  iMessage is a completely different protocol only works with Apple devices.
And just to add a bit.
Turn on your Wi-Fi or Data....if messages come in....then they are iMessages
Make sure airplane mode is off.
@iliketotalk so true lol
Austin_YQU
Log into your account and be sure that it is active
If it is, restart your phone
If not working, get a ticket going
popping
gblackma
@Pcm  what's the make and model of your phone?  Thanks.
@Naepalm
@Naepalm wrote:
So this is a question? I think much of the community will end up pointing you to either Self-serve or a moderator.
Common question:
Is your account inactive status?
Does the rest of your service work?
Do you have an old plan that only has a limited amount of texts?
@Naepalm  are you just thinking out loud lol
Naepalm
Common question:
Staliger
@Pcm Is your account active? Do you have enough funds? Try restarting phone/enabling and disabling fly mode/ taking out and inserting back the sim. If din't help, click ? on bottom right and follow directions to contact moderators.
geopublic
@Pcm  Can you make/receive calls? Can you send texts?
