01-09-2020 11:11 AM - edited 01-05-2022 08:57 AM
I added the 400 min international call add-on a few days ago and successfully called the UK. I've just tried again and it rang but noone answered. When I called back ten mins later suddenly it's telling me that I don't have a talk option and it won't connect the call anymore. I've only used 17 out of 400 minutes.
Joining Public
01-17-2020 09:14 PM - edited 01-17-2020 09:14 PM
Most international calling problems relate to whether you've dialled 1 or 011 before the call and an understanding of country and city routing digits.
AE_Collector
01-09-2020 02:11 PM
You might need to check the country code and see if the dialer is adding a + before the number or not to specify different country.
01-09-2020 12:19 PM
@slhudson23 If it keeps happening on a regular basis then best to submit a ticket to PM and ask then to reset your account from their end.
To submit a ticket to the Moderator Team, please start a conversation with the Public's virtual assistant, SIMon by clicking the icon below:
If you are still having problems contacting Public Mobile then click here. The link sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
01-09-2020 12:15 PM - edited 01-09-2020 12:26 PM
@slhudson23 wrote:I added the 400 min international call add-on a few days ago and successfully called the UK. I've just tried again and it rang but noone answered. When I called back ten mins later suddenly it's telling me that I don't have a talk option and it won't connect the call anymore. I've only used 17 out of 400 minutes.
@slhudson23 If addon shows in your account, it is still there and activated. As was recommended previously, try to restart your phone and dial the phone manually typing the numbers. If it didn't help, you can contact moderators for further assistance: click the "?" in lower right side of the page, type "contact moderator", and follow directions.
01-09-2020 11:59 AM
Restart your phone and try again. Check the number you dialed is it identical to the previous.
Try again, sometimes there is a misconnetion I get an error dialing out my mother whom I call every day - just hickups of the system. Seems to happen more during work hours
If it persists contact the moderators by clicking on the question mark in the bubble at the bottom right
01-09-2020 11:19 AM
@slhudson23, try rebooting the phone, close and restart the phone app. Sometimes software glitch could give rise this kind of stuff.
01-09-2020 11:17 AM
Are you manually dialing or using your call log to redial? A small mistake in the number would result in an invalid number and I belive that Public Mobile plays back an incorect automated message when that happens. I can only suggest to try the call again later.
