No service
MyaGray
Trying to dial the  *611 to reload my prepaid card onto my phone and the phone disconnects before even one ring. And has been like this for days. What is going on.
HI @miyazada   you might want to keep calling *611.  Some people able to get via it after enough tries
Or , can you login to My Account?  Use My Account instead
if you cannot login, try the Reset Password, or submit ticket with PM CS agent for them to help resetting it
Please submit ticket at : https://publicmobile.ca/chatbot.
First type Forgot Login,
miyazada
The number 18554public is not a solution,it’s not working
miyazada
Same here, what the solution?
Dunkman
@MyaGray
Some customer have issues dealing 611 the last couple of days. PM is aware of the issue and working on a fix.
https://productioncommunity.publicmobile.ca/t5/Announcements/Ongoing-Issue-611/td-p/963252
Try:
from any phone dial 1.855.4PUBLIC, enter your phone number, it works just like *611.
@MyaGray  Get support
  • Get support by starting a conversation with virtual Chat box /SIMon. Click here
  • you can send a private message   To CS_Agents by clicking here.
  Watch for reply top of page to the
   Right ( envelope image )
