No service
09-07-2022 06:17 AM
09-07-2022 04:02 PM
turn off device take out SIM card and if you have other device to tried SIM card it's will works.
- How to > Reset Network Settings
- check APN settings >> How to Set APN
- go to Settings-> Cellular-> then tap the switch to enable Cellular Data.
- Update iOS > Go to Settings > General > Software Update..and rebooting device.
09-07-2022 06:31 AM
Do you have SMS text or just iMessage? When you paid and reactivated did you do it through your self-serve account or through 611? Call 611 on your phone and see if the message tells you whether you are active or suspended?
09-07-2022 06:30 AM
@Ada16 - if you are using iMessage, then you may not be using SMS. Is calling in/out working?
Confirm your account status says Active in your My Account, or by calling 611.
If active:
Try 1 or more of the below:
- restart your phone
- toggle into and out of airplane mode
- perform a Reset of the device's Network Settings
- move your sim card to another phone to see if services works
To perform a Reset of your device's Network Settings. This also resets Wi-Fi networks and passwords, cellular settings, VPN and APN settings, and connected Bluetooth devices that you've used before.
To Reset Network Settings, begin by opening the Settings app. Next, tap General -> Transfer or Reset iPhone -> Reset -> Reset Network Settings. and enter your passcode.
Your iPhone will reset network settings and restart itself.
09-07-2022 06:26 AM
Yes I just renew, I got text but that all ,no data or calls
09-07-2022 06:23 AM
I was gone two months of the country so I didn’t paid my plan until now ,the model of my phone is an iPhone XS,I got messages ,but when I activate the data it doesn’t work
09-07-2022 06:23 AM
@Ada16 Did you just renew? Are other parts of service working?
09-07-2022 06:20 AM
Your other services are working? Did you just activate? Or is tonight your renewal? What's the make and model of your phone,?
