12-23-2021 12:23 PM - edited 01-04-2022 04:50 AM
Extreamly disappointed with public mobile have had no service since I paid for the plan and nothing has worked poor quality and bad service
Joining Public
12-23-2021 06:36 PM - edited 12-23-2021 06:39 PM
PM is a prepaid cell provider so no refund.
Did you power off the phone when you insert the SIM in the phone?
Try that…if that doesn’t work. Contact a CS_Agent by clicking on the SIMon chat button then type in Create a Ticket then follow the prompts.
My friend had the same problem and the CS_Agent fixed the problem the next day. He forgot to reply to the SMS text with YES after the 90 minute window.
12-23-2021 12:55 PM
are you getting new number or Transfer your old number to public mobile, if so
do you get a SMS message from your old carrier asking to confirm if you would like to Transfer your number. Your reply should be: YES.
if you miss it put it back your old SIM card and try to see the SMS,
if you stuck with Transferring your old Phone Number, or is not complete processing
Here’s how to contact Customer Support Agent by CS_Agent,
- you need to send a private message to Customer Support Agent by CS_Agent, by Click Here link.
- please include in your message,
- phone number,
- which carrier,
- Customer Support Agent by CS_Agent, will Response to your inbox by private message
- During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
- Monday to Sunday: 6 AM to 10 PM EST
- Note: Public Mobile No Support by phone call or Email.. only by CS_Agent, private message..
- Check your private message inbox (click on the envelope top right of your screen)
and do some troubleshoot your device,
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
APN Settings On An IPhone
click Here link,
and try manually selecting network "3G ONLY"
for iPhone visit Here link
or Here link
and do Rebooting your phone ,This is quick and simple,to refreshing your network,
*what is meant by rebooting the device turn off and turn it back on.
try to check update your device,
12-23-2021 12:38 PM
Maybe your SIM is defective?
Did you port your number from another provider? It takes day to two for everything to gets settled.
Stuff happens and that is no reason to say 'bad service and poor quality'.
If you are patient enough all issues will be resolved.
12-23-2021 12:35 PM
Try rebooting your phone. Also removing and reseating the sim.
12-23-2021 12:31 PM
@Jadont wrote:I joined yesterday around 5pm my account says it’s fully activated but I have no service no matter what I try I’ve tried my sim in another phone turning off my phone resetting my phone and all my network settings, still no service I have an I phone 8 is there anyway can be refunded if it still won’t work by tomorrow?
Hi @Jadont @ did you try reboot your phone? you tried to put your SIM on another phone to test?
sometimes there is problem with activation, open a ticket with PM support and they will look into it. click on the Bubble on the lower right or directly at : https://publicmobile.ca/chatbot.
- type: Activation
- click "Activation isn't working"
- click "Other/Error code 821"
- click "Contact Us"
- Click "Click here to submit a ticket"
- you will then direct to another page to open ticket.
12-23-2021 12:31 PM - edited 12-23-2021 12:31 PM
@Jadont Did you bring your number from another provider or you selected a brand new number?
Connect your phone to a computer and open iTunes. See if it pushes any updates to your phone.
12-23-2021 12:30 PM
There are no refunds on prepaid services.
Were you porting your number from another provider? If so, did you respond yes to the port authorization request by leaving your old provider SIM card in your device?
12-23-2021 12:28 PM
12-23-2021 12:27 PM
3 more things to check:
- Is your device compatible
- Could it be blacklisted or locked to another carrier
- Is there a service outage in your area
12-23-2021 12:25 PM - edited 12-23-2021 12:26 PM
Can you give us a little more details of your situation please?
Are you a new customer activating? Are you porting your number from another provider?
Did this happen on or around your renewal date?
You could sign in to self-serve and check to see if the status of your account is active.
While you're there, check the change SIM card feature to ensure the last four digits listed there matches the last 4 digits of the SIM card in your device.
12-23-2021 12:24 PM
@Jadont When did you join? What's working and what is not working? What model phone do you have?
