09-27-2020 04:36 PM - edited 01-05-2022 01:22 PM
I just activated my sim. It worked for 5 mins and now I have no service. Can we get this fix asap.
My phone number is xxxxxxxxxxxxxxxx
Thank you.
edited by computergeek541: phone number removed
09-27-2020 08:48 PM
We need to know what kind of phone you’re using. Then we can suggest you first try enabling airplane mode for 10 seconds then disabling it to see if it finds the network. Then depending on your settings, we would recommend a network setting reset. You can also try taking out the SIM and putting it back in.
09-27-2020 06:56 PM - edited 09-27-2020 06:57 PM
@joerome wrote:We could not create a login because it said no service. It cannot receive text messages
PM will send you a welcome email after activation.
Even your activated SIM card is not working on your phone. You should receive the PM welcome email. Use your email address as the username and the password you provided during activation to login to your self-serve account. https://selfserve.publicmobile.ca
If your account status is active and nothing works, create a moderator support ticket for help using this link https://publicmobile.ca.ada.support/chat/
09-27-2020 05:35 PM
That was my initial thoughts.
The phone is not blacklisted.
09-27-2020 05:25 PM
@joerome Try the SIM in a different phone, and a different SIM in the phone. What is make/model of the phone?
That behaviour can occur if a phone has been reported stolen. Check here to see if your phone has been reported stolen: https://www.devicecheck.ca/check-status-device-canada/
09-27-2020 05:11 PM
09-27-2020 05:10 PM
I am a public mobile dealer. So we have tried all the basic solutions.
09-27-2020 04:49 PM
@joerome wrote:I just activated my sim. It worked for 5 mins and now I have no service. Can we get this fix asap.
I would start with the simple things as a an elimation processs. Start by restarting the phone/device. That can sometimes cause the phone to reconnect. By no service, do you mean no calls, texts, or data? Does the signal meter show as you being connected?
09-27-2020 04:49 PM
Can you log into self service to see if your plan is active?
09-27-2020 04:48 PM
@joerome , is your account in active status? We are just customers helping customers here. We need more information in order to direct the suggestions.
09-27-2020 04:47 PM
Thank you for moving this to the correct page. But in the mean time, can we get this fix asap.
Thanks.
09-27-2020 04:38 PM
