No service
Hyatt
I have no service, my account is not delinquent, SIM card was not changed but taken out and replaced immediately, checked settings . Still no service. What should I do next?
8 REPLIES 8
Jmoreland
Do you have WIFI service if not this might be something wrong with your phone.
popping
If your account status is active,
1.  Test your PM SIM card with a working phone to determine whether the issue is your phone or PM provisioning issue.
2.  Adding $1 to your account may trigger PM server to provision your account again.  Restart your phone and test again.
gblackma
@Hyatt are you getting an emergency services only message? If you are, log into your self service account,  choose the change sim card option and compare the last 4 digits to the sim in the phone.  They should match. Thanks.
Luddite
@Hyatt  As you say you have paid in full, but have no service, you likely need assistance from the moderators.
To get a ticket click https://publicmobile.ca.ada.support/chat/ and enter your question into SIMon.  Invent prompts until you get to the Contact Us button, click it and a Submit Ticket button should appear. Click it then login and pick the topic, if needed, from the drop down menu. To confirm your ticket has been submitted, check the SENT box in your private messages; click the small envelope beside your avatar at top right on your screen.
@Hyatt
Do you have another phone you can try your sim card in.....? You have access to your account?
public1125
@Hyatt
Try the things that @gpixel4  suggested after you tried the ON and OFF trick with then phone.  Those should take care of it.
If those do not work, you might have a problem with sim slot or maybe the sim. Can check to see in settings if the phone recognizes that a sim is in place
gpixel
@Hyatt
  • check again and make sure the sim is seated correctly
  • try resetting your network setting
  • toggle airplane mode on/off
  • reset your sim in your self serve account by enable/disable lost/stolen mode
whats the make and model of the device?
public1125
@Hyatt
Have you tried to power cycle your phone?  Some phones require it to be turned off and then on for it to read the sim that was just reinserted
