No service
Bandsaw
I am getting the Not registered on the network this morning.seems that a lot of folks are having trouble around the province. Tried using the submit ticket feature, and 404 error.
If this is a widespread outage, how about posting a notice About it, or at least fix the ticket system.
@CS_Agent
dabr
@CS_Agent
@Bandsaw   As noted by @LovesToPM  there seems to be some network disruptions and hopefully they are restored by now or will be shortly.
If you encounter problems with SIMon, you can always, as your second option, try contacting the Moderator_Team via the envelope icon next to your avatar above your post.  However, you may experience a bit longer wait for a response from moderators via messaging than the chatbot option, although recently there seems to a generally shorter wait period for either method.
LovesToPM
Telus and Bell experiencing cell service disruption in parts of Ontario.
https://downdetector.ca/status/telus/
Issue is being looked at and there are reports of service returning for some clients.
Lemony_Snicket
What part of the country are you in?  Working fine in Toronto.
