11-11-2016 09:21 PM - edited 01-04-2022 06:15 PM
Looks like anyone on a telus network is going to my PM sim and not to my non ported sim on Zoomer(rogers). I run a snall business and would have never even considered this as an option if I knew this was going to happen.
The mod I pm'd hasn't responded or mentioned if I'm in any type of que. Registered on Tuesday still nothing.
11-11-2016 10:28 PM
Tag them using the @UrbnRzqr
get their attention
11-11-2016 10:06 PM
It is not the promotion that is causing the issue, it's their system that glitches for whatever reason (which they should try to fix).
And because there is a lot of people that are signing up for this really good promotion and running into whatever problems (account, porting, etc) , they are backlogged trying to fix users' issues.
You can check if your private message has been read or not when you click into the private message you sent.
11-11-2016 09:56 PM
I think, personally, in the future, PM should ensure that issues like that Promo are absolutely minimized, they canèt have this issue happening over and over, it's kinda painful, and can leave a bad impression, hoping PM learns from this and becomes better at what they provide
11-11-2016 09:31 PM - edited 11-11-2016 09:31 PM
The mods are swamped with questions/issues because of the hot promo.
Did you port from telus to pm?
