03-12-2023 09:05 PM - last edited on 03-13-2023 12:02 AM by computergeek541
I cannot text or make calls since I cannot see the public mobile network on my phone's network settings. I see Bell, and Telus. The bot couldn't supply a ticket to get in contact with a CSR.
03-13-2023 09:59 AM
Strange it was working, and now it is not.
Do you have access to another provider's SIM card you can put inside your phone to test if there are working services?
Try that and let us know if it works.
03-12-2023 10:05 PM
I have had it on auto network as well. Noticed at top of phone it's always been public mobile. Tried connecting to Telus network and no luck. Will try again. Appreciate ur thoughts 😌
03-12-2023 10:02 PM
I've logged into account and confirm it's active 👌. Thx for help
03-12-2023 10:02 PM
Yup thinking it's my device. Switched to another phone and worked fine. Tried that link to see if phone blacklisted but its ok. My phone is a Samsung S21 FE. It was working fine a couple weeks ago and I went to the states then on holidays. Just got back and went to text but no luck. Gonna get in contact with support. See if I have something not set right on phone. I can see two networks in Bell and Telus available but unable to connect to either. Also phone next to me is on public mobile as well with a Sim card. Absolutely no issues with that one. Very strange as I've tried most everything. Appreciate the help. Cheers
03-12-2023 09:43 PM
@Funkymojo , is it possible that there might be a network labeling issue on your phone? I have a Chinese branded phone that shows Telus on certain settings tabs and Public Mobile on others. From the mobile network tab, it shows Telus. Elsewhere it shows Public Mobile. I have never had any problems as I have the phone settings to do auto network connection.
03-12-2023 09:42 PM
Confirm your account is Active by calling 611 from your phone or logging into your account.
03-12-2023 09:38 PM
@Funkymojo if the phone next to you works fine, then it could be your device.
what exact model is your phone? And the phone status shows not connected?
For peace of mind, check if your phone is blacklisted here:
03-12-2023 09:31 PM
Just loss connection. Also did reset which included network settings for wifi and Bluetooth. Still no luck. Removed Sim card and reinstalled. Gonna try in another phone now. However a phone next to me on public mobile is working fine lol. Beats me. It was working till today. Thanks for the info 👍
03-12-2023 09:19 PM
@Funkymojo did you just join PM and unable to connect??
or you just loss the connection??
Try to click Reset all networks and it could resolve it quickly
Also, try your sim on another phone as well
03-12-2023 09:09 PM
Thx Handy1 for the reply.
03-12-2023 09:06 PM
Here’s the link to contact support
Watch for reply top of page to the
Right ( envelope image )
