No phone reception
suebutcher
not able to make or recieve calls      as of today
What is problem
7 REPLIES 7
suebutcher
All working one day after problem
rebooted phone, thx for your help
THX
@suebutcher
    Was your renewal last night? Your Auto pay may have failed. Check your account and see what it says. If it suspended make a payment and reactivate. Reboot phone.
      If this is not the issue try rebooting your phone. If that doesn't work try turning airplane mode on. Wait 10 minutes. Turn airplane mode off. See if it connects to the network. Make a call.
What is problem
As for the no reception part, does it say anything on the phone's screen such as emergency calls only, invalid sim, or sim card not provisioned?
CannonFodder
@suebutcher  Yeah, not exactly much info to go on there.... some answers to the other posters' questions would definitely help.
gblackma
@suebutcher when did you activate your plan? And has it ever worked properly? Did you port your number over? And if you did, was it a cell phone or landline? Thanks.
What is problem
scorpio17
What about SMS? What plan do you use?
What is problem
What is problem
What plan are you on?
Maybe you're on the $10 plan and you've used all your minutes.
Or your plan has expired and you account is suspended.
