No network
Inder_
Plz no network?I just port a number from another provider yesterday till no signal
2 REPLIES 2
eddieO
Did you reply yes to the text message front your old provider for transferring your number? Have you tested your old SIM card to confirm you can no longer call out our receive calls?
hi @Inder_
you account not properly setup , you will need help from support agent.  Please message them using the link :
