No more talk+text plans?
BaltazarR
I wanna downgrade my plan to just a cheap talk and text plan with no data, the cheapest they got. Is there not any available? When I try to change subscriptions I can’t find anything cheaper than my $35/m plan with 60GB
@BaltazarR
You will need to login to your account on thePM app or website then to Subscription>Manage Subscription>Change Subscription. It will list all plans you are eligible to change to.
All PM plans will have data. My account is showing a $19 plan with unlimited calling and texting with 1 gb of data.
Plans varies to all members.
Sorry @BaltazarR , the Talk + Test plan is a plan for new subscriber only.  For existing subscribera, the available plan change is limited
