No incoming calls on PM number
Tsflui
samsung s3
still on PM number and incoming calls goes straight to voicemail.  Any clue why? I haven't ported my number yet.
Everything else works
It's something with the S3 because the card works fine on my iPhone.
Please help!!!
8 REPLIES 8
Tsflui
I figured out my problem thanks to the "do not disturb" tip, the Samsung has an option of " call reject" setting that was on auto. Once I turned the option off the phone received calls.  I ported both our numbers from Fido and bell and everything went smoothly and everything works! Thank you PM community!
Now after porting our numbers should I still check to see if our old providers cancelled our services?
Antiloop
Lots of people are having this exact same issue.
At this point, all you can do is send a MOD a message with all your details and hopefully they get to it.
I have been waiting a few days now, with no response.
aghadimi
No, I didn't
cactus_ch
Did you guys receive a text message from public and mentioned port complete or successfully?  I finished port at the same day and received sms from public saying porting completed.
aghadimi
I have the same issue,I ported my number from Wind yesterday and everything works except all incoming calls go to VM. I sent private message but no response.
Please help!!
cactus_ch
Have you enable call forward feature?
lukevader
Do you have "do not disturb" activated on your s3?
mohamed_mohamed
How come you can make calls and your number has not been ported yet !!
