No data
05-19-2023 08:57 AM
05-19-2023 10:12 AM
@Momma22 what plan you are on? $15?
05-19-2023 10:08 AM
What about incoming calls? texts?
I assumed that these features were working before.
If you have another phone available, you can put your SIM card in that phone. This helps determine whether PM service issue versus hardware problem.
Did you try a phone network setting reset as mentioned earlier post? Note: this will erase any saved wifi password setting.
05-19-2023 09:53 AM
It is active and in good standing
05-19-2023 09:52 AM
I don't see that option for messages
05-19-2023 09:40 AM
My account status is active and all good
05-19-2023 09:32 AM
@Momma22 @Try going into setting and reset all setting, if they dosent work click on the = at top left of ur screen on this page and click on your message,then click the lil box with pen on bottom right to send a new message under send to enter csa_agent and then write ur issue in the message box that will put you through to an actually agent and they will certainly help fix issu
05-19-2023 09:31 AM
Try going into setting and reset all setting, if they dosent work click on the = at top left of ur screen on this page and click on your message,then click the lil box with pen on bottom right to send a new message under send to enter csa_agent and then write ur issue in the message box that will put you through to an actually agent and they will certainly help fix issue
05-19-2023 09:24 AM
@Momma22 you cannot dial out too
did you check account Status, is it active? please check using Incognito mode
05-19-2023 09:19 AM
@Momma22 - you can't dial out either? Well that could be another issue, unless there is a network outage. Did you check for outages?
Can you receive calls, and how about texts?
I was going to say regarding your data issue, do you have a data delimter on your phone in the settings, this will prevent you from using data if you reach that limit. So change the limit or turn it off if you have it on.
But since your outgoing calls don't work...try manually select the 3G / WCDMA ONLY network in your Mobile Connections area in your settings (temporarily) to see if this helps with calls.
If this and other troubleshooting suggested is not working, see if this is an account issue with CSA.
To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them found here:
05-19-2023 09:15 AM
Hello, I have removed and replaced the Sim card, turned data off and on. Turned the phone off and on. The status of my account is active.
05-19-2023 09:14 AM
Hello, yes. I have turned it off and on. Turned the phone off and on. I can't dial out either.
05-19-2023 09:03 AM
Did ypu check to see if mobile data is turned on in your setting?
05-19-2023 09:02 AM
@Momma22 was data ever work on this phone?
couple things to try/check
- reboot your phone
- login My Account using Incognito mode and confirm if account status is active
- check if you have data limit enabled in your phone, disable it
- what brand and model is your phone?
05-19-2023 09:01 AM - edited 05-19-2023 09:02 AM
@Momma22 - there are usually data issues posted daily, but for all sorts of reasons.
What troubleshooting have you tried, more details would be helpful. So until then, I guess or suggest things.
Does calling and texting in/out work okay? If not, is your account status ACTIVE in My Account or when you call 611?
ADD, do you have data left on your account, ensure to click the little circle refresh button to see latest data or log into My Account through an incognito mode tab. You may also call 611 to check data balances.
Try 1 or more of the below:
- restart your phone
- toggle into and out of airplane mode
- perform a Reset of the device's Network Settings
- move your sim card to another phone to see if services works
Check for outages in your area:
https://www.telus.com/en/on/outages
https://istheservicedowncanada.com/status/telus
https://downdetector.ca/status/telus/map/
Edit
