No data
jclark416
  • Hi,
 My account shows that data should be available but I can’t access it
HALIMACS
@jclark416
I presume your mobile data is toggled ON?
Also, does calling and SMS both in and out work?
@jclark416  Reboot the phone and
Try again incognito/private mode
And or lap top /computer
                    OR
simply try refreshing the page to check data plan / mins / add ons
Chalupa_Batman
Hello there @jclark416
Depending on if you have data left in your bank for the remainder of this cycle, try this.
Go to Network Settings, turn off "Automatic" and choose Public Mobile. Reboot your phone and give it a try. Also, if you're using an iPhone, the iPhone browser sucks! Use Google Chrome. Let us know if this works.
Hollister
dust2dust
Click on all the little spinner refresh icons you see lower down to make sure you're seeing current info.
Do you have a data limiter set on the phone (if Android)?
