11-09-2019 05:00 PM - edited 01-05-2022 09:41 AM
Well just moved and the town just installer a tower. Yet I can't receive or make calls. Internet works text messages work.. but no calls.
This is what the tower company just posted on Facebook. If u can Help me please do.. I got a lg G6
Here is the message from Facebook.
Today I visited several residences that border the towers that cover Route 155 and that had highlighted connection problems. In 100% of cases, the problem was the customer's cell. Please call technical services directly from your suppliers and make sure that LTE Voice mode and your sim card is open for this service and that the provider allows you to use the VOLTE (or HD at koodoo) mode. Do not go through your dealer call the supplier directly.
11-10-2019 02:43 PM - edited 11-10-2019 02:44 PM
Does your phone work for calls when you go somewhere else, different town? Is it only when you are in that specific area, or everywhere?
11-09-2019 09:04 PM - edited 11-09-2019 09:06 PM
@johnwarnock2017Unfortunately from your Faceobook message, for your voice to work, it needs VoLTE, a service which Public Mobile doesn't provide. You would need to upgrade one tier to Koodo and use a Koodo issued phone "Be using a VoLTE compatible phone purchased from Koodo°. Bring your own phone(BYOD) from other carriers will not be compatible with this feature." in order to have voice..
https://www.koodomobile.com/en/help/voLTE
11-09-2019 05:27 PM
@johnwarnock2017 wrote:I've been with public Mobile for 2 years now.. only moved 30km away from other town.. the new town we didn't have any service here.. now we got a new tower.. everything works except for Calls
It could be LTE-only tower. If it is, you can't do calls.
11-09-2019 05:24 PM
11-09-2019 05:20 PM
@popping wrote:Did you just port your number to PM?
If yes, you need to wait until your old provider release your phone number to PM before getting incoming calls and texts. If you old SIM card is still working, continue to use it until it stops working. Then start using PM SIM card.
For LG phone, you need to do a network reset after switching to a new provider before your data working again.
I don't think it's a porting issue because he can't make outgoing calls.
11-09-2019 05:20 PM
Shot in the dark but since you have an lg phone, you might want to try a network reset.
Lots of evidence for this when switching providers. Perhaps new towers may require reset as well.
11-09-2019 05:16 PM - edited 11-09-2019 05:17 PM
11-09-2019 05:03 PM - edited 11-09-2019 05:19 PM
@johnwarnock2017 wrote:Well just moved and the town just installer a tower. Yet I can't receive or make calls. Internet works text messages work.. but no calls.
To get a new tower online, they have to install and configure. This could mean adjustment to neighboring sites.
This morning, there was discussion of an outage in Ontario.
