06-16-2022 12:04 PM
I have already paid for the plan but there is no signal on the sim card, this is not a new service I was already using it in the past but now when I try to use the phone it was not working.
06-16-2022 03:39 PM
Is your phone and sim card working now? Otherwise I was going to suggest contacting customer support to reprovision your sim card with a small possibility that your sim card just died and you would need a replacement sim card?
06-16-2022 12:38 PM - edited 06-16-2022 12:46 PM
@Aartibabbu wrote:no, it is not blacklisted.
@Aartibabbu Great it is not.
So, your PM My Account showing Active now?
Do you have another phone to test it out if the PM SIM works on another phone instead?
06-16-2022 12:36 PM
06-16-2022 12:34 PM
@Aartibabbu just for peace of mind, check if your phone is blacklisted here:
06-16-2022 12:24 PM
yes, i have already done all that
06-16-2022 12:24 PM
iphone 12 , last month
06-16-2022 12:23 PM
yes
06-16-2022 12:12 PM
Did you try to reboot phone? Reset network settings? Re-seat SIM? Try SIM in another phone?
06-16-2022 12:09 PM
@Aartibabbu What kind of phone is that? brand and model?
When was the last time you use this phone on PM network and was working?
or this phone has never work on PM network before?
06-16-2022 12:07 PM
Do you get the same result when you put the sim card in another phone?
