07-01-2022 04:13 PM
I canceled my TELUS account and activated a Public Mobile account but when I put in the Public sim card I still have no service. What am I doing wrong?
07-01-2022 04:48 PM
@JeannettePink oh..like cancelled, cancelled? How long ago?
Call Telus to tell them you want to port the number...OR, contact CSA here at public to see if they can recover the number..if possible.
Public Mobile Representatives customer support agents (CSA) can be contacted by either two methods, found here:
07-01-2022 04:16 PM
@JeannettePink hello did you transfer your number to public if so you need to leave your tellus sim in to receive meesage to transfer reply yes also your tellus account needs to be active or they won't release number
07-01-2022 04:24 PM
@JeannettePink If you cancelled your service you won't be able to transfer your number unless you call them, they may release it since it's the same company
07-01-2022 04:36 PM
no I switched sim cards right away and didn't get a message from telus
07-01-2022 04:37 PM
@JeannettePink - if you replied to the SMS text on the Telus SIM card try restarting your phone.
Also check self serve that your account is showing ACTIVE, or call 611 with the PM SIM in your phone to check.
And, you can also try a reset of your network settings on the device.
07-01-2022 04:38 PM
@JeannettePink how long was it since you request porting?
There is a number you can call to talk to live support person. they can retrigger the process. I will private message you the phone number. Check the Community inbox, envelope icon on top right
07-01-2022 04:42 PM
Yes I asked for my number to be transferred but unfortunately did not know to wait for telus message
now I've canceled telus account and not sure how to get my public sim account to work
07-01-2022 04:48 PM
07-01-2022 04:59 PM
The Public Mobile account having no serrvice isn't a number porting issue. You will need to also get that sorted out.
07-01-2022 05:05 PM
ok I just got telus to reactivate my account
now how do I request another message from them to transfer the number?
