06-04-2021 09:50 AM - edited 01-06-2022 02:49 AM
I have not had cell service on my iPhone for 2 days. I have switched to airplane mode and on again.... wifi is working but can't phone or text. I am on vancouver island
anyone else having any issues
Service
06-04-2021 09:59 AM
@proway wrote:My account is active and paid up to date
data doesn't seem to work either
Just try to remove the sim from the phone. After a moment, put sim back in the phone and restart.
It's a long shot..... but give it a try and let us know.
Good luck.
06-04-2021 09:57 AM
thanks....i will try that
06-04-2021 09:56 AM
06-04-2021 09:54 AM
Dunno if it'll help but when I was using an iPhone I found that in the settings under cellular, when it was set to detect the carrier automatically it would NEVER stay connected. I switched it over to Manual and chose Public mobile (or whatever carrier I had at the time) and never had an issue after that.
06-04-2021 09:53 AM
@proway wrote:I have not had cell service on my iPhone for 2 days. I have switched to airplane mode and on again.... wifi is working but can't phone or text. I am on vancouver island
@proway did you check your My Account to see if your account is active? How about Data? does it work?
Which plan do you have?
