No Service
sabumbeejay
I inserted the SIM card and did not get service. I assume the service is the same as TELUS? Please help!!!
sirvar
Also, phones can be unlocked for free now. Might want to do that just in case you travel and need to pop in a SIM there
It is probably the activation isnt complete properly. mod is the only fix now.
sabumbeejay
Yes, I can't log on to my account. Thanks, I will mail the moderator now.
@sabumbeejaywrote:
Yes, I activated my SIM card and I was charged for it. So I go home tonight and inserted it into my iPhone 6 but it indicated 'no network'. I had my phone was unlocked months ago when I was in Britain. I was with Telus.
Login to your self-serve account and see if everything looks ok. If you can't login to your account, there might have been some error during activation. In this case, you will need to send a private message to the Moderator_Team with your account info.
sabumbeejay
NDesai
@sabumbeejay Did you activate the sim? If yes, did you get charged? Did you receive any errors? Is your phone unlocked or locked to Telus/Koodo?
We need more info in order to provide some help.
